Sunday, September 15, 2019
Error installing Vijeo Designer 4.6.0
When I try to install Vijeo Designer 4.6.0 I get an error message:
Setup has experienced an error.
Please do the following:
-Close any running programs
-Empty you temporary folder
-Check your Internet Connection (Internet-based Setups)
Then try to run the Setup again
Error Code: -6001
What is the reason? My temporary folder is empty, other programs are not running, Setup is not internet-based. What is the error -6001?
By Tamas Varga on 3 June, 2008 - 12:58 am
Error 6001 occurs at installation of Vijeo Designer v4.6 if there are old installations DLL that are not up-to-date.
Delete or move all files from this directory:
C:\\Program Files\\Common files\InstallShield\Professional\RunTime
Then start installation.
Thanks! Again, I am amazed when I get this kind of problem...! Schneider is not a small company, how come the installation process of this product (VIJEO) is so weak. The first thing you do when you generate an "inatall package" is to make sure it is the most "autonomous" as possible. Which is obviously not the case here ... :-)
By Colm Heneghan on 31 March, 2009 - 5:05 am
This works perfect for me. Dont understand why this happens. Shouldnt Telemecanique/Schneider Electric sort this out??? Im going to contact their sales rep about this. If it wasnt for these forums we would be lost.
By programer on 4 June, 2008 - 12:02 am
If you have the previous ver. installed, please remove it first from settings, or just to upgrade your DLL files in the program help>about>upgrade
By prabhu abraham on 17 September, 2008 - 2:14 am
First of all you have to change your installshield. For that purpose you should do the following things,
1) c\:programefiles\:common files\:installshield
You have to rename the installshield to some other name such as vijeo or something like that. In that way you can continue the install procedure.
If you try to install Vijeo Designer in a computer HP, try to uninstall the software "HP Help & Support Center (HSC)"
It's maybe the solution...
Old thread but your procedure works.
Thanks!
