P
I am aware of the S90 TRIPLEX protocol that is used to communicate between the RX3i PLCs and Cimplicity HMI. This one is an address based protocol which demands that each variable that is being used in the PLC should have a unique memory address.
And since RX3i does not have automatic variable addressing, the programmer has to assign address to each variable.
Is there any way to communicate with Cimplicity HMI based on the NAMES of the variable so that there is no need to assign memory address to the variables in PLC?
