I wanted to know what benefits if any, there would be to partially installing screened motor cables from a VSD. I have an existing unscreened motor cable run of about 45 metres from VSD to motor, with a junction box 5 metres from the motor. Would I get an noticeable noise screening if I was to replace the last 5 metres from the junction box to the motor, with screened cable?
I have sensitive electronic equipment mounted next to the motor and cable from junction box, but can not relocate or separate the motor cable or electronic equipment. Replacing the entire motor cable run with screened cable is not an option.
