Hi All,
We have an intermittent problem on our mark 5 speedtronic control of a frame 6b turbine. Sometimes the field swich doesn't close and the machine sits at synchronous speed with no volts. We can manually close the field switch, volts come on and it sync's and closes the gen cb.
We looked into the wiring and software and couldn't find any fault. Changed the interposing relay between the Mark 5 output and the field swich contactor. The field flashing is the first contactor where 125vdc is put on to get it started then it changes over to a generated supply. We're not getting the field flashing. Once the field swich is closed manually, the change over from dc field flashing to the generated supply is ok.
We also changed the manual field switch open pushbutton which has a n/c contact which is in circuit for the auto field switch as there was some resistance across it. Seems to be a timing/software problem hence the intermittent nature of it. Has anyone else had this problem? It has happened on both of our machines hence why why I think it's a s/w glitch rather than a hardware/wiring fault. software only needs to see master protective healthy and correct speed. Any comments or proposals to troubleshoot are welcome.
Thanks,
David
Thanks,
David
