Induction motor used barring gear of STG is not getting rotate through soft starter even full voltage is applied by soft starter in 5 to 7 sec. But if I am providing full voltage through DOL, then motor is running normal.
If soft starter is providing full voltage after 7 to 8 sec then motor should rotate. In DOL it is working fine.
