I want to transmit the 4-20mA output of Sepam S42 to a PLC. What I understood from Sepam manual is to use the MS 141 communication module and the Modbus RS 485 2 wires interface and configure the relay by entering the parameter to be converted to 4-20 mA and the min and Max corresponding to 4-20 mA.
Is that correct? What are the hardware requirements?
Thank you
Thank you
