I previously connected to the DCS800 and completely went through the wizard successfully. Now, a few months later, I went to connect using a different USB to serial connector and now I'm getting a "no drive detected" window as well as an ".ini file not found".
I've checked my com ports multiple times and made sure they are set up the same way they were last time.
Any suggestions?
Thank you!
Any suggestions?
Thank you!
