Saturday, July 20, 2019
Automation Protocol Through Ethernet
Is it possible to communicate multiple TCP IP protocols through a single port?
Suppose I have a PLC (Only 1 Ethernet Port) which support Profinet, DNP3 (TCP IP), and Modbus TCP IP.
Can I get data using these protocols simultaneously through the Ethernet port of PLC?
Yes assuming the PLC can handle the load and supports all the protocols.
Good luck,
Mark
http://www.peakhmi.com/
Since these protocols have different TCP Ports assigned
1 Ethernet interface can handle all of them at the same time.
lehrig@nb5lehrig:~/Downloads> grep -i profinet /etc/services
profinet-rt 34962/tcp # PROFInet RT Unicast [Peter_Wenzel]
profinet-rt 34962/udp # PROFInet RT Unicast [Peter_Wenzel]
profinet-rtm 34963/tcp # PROFInet RT Multicast [Peter_Wenzel]
profinet-rtm 34963/udp # PROFInet RT Multicast [Peter_Wenzel]
profinet-cm 34964/tcp # PROFInet Context Manager [Peter_Wenzel]
profinet-cm 34964/udp # PROFInet Context Manager [Peter_Wenzel]
lehrig@nb5lehrig:~/Downloads> grep -i dnp /etc/services
ndnp 2883/tcp # NDNP [Khelben_Blackstaff]
ndnp 2883/udp # NDNP [Khelben_Blackstaff]
dnp-sec 19999/tcp # Distributed Network Protocol - Secure [Grant_Gilchrist]
dnp-sec 19999/udp # Distributed Network Protocol - Secure [Grant_Gilchrist]
dnp 20000/tcp # DNP [Michael_Thesing]
dnp 20000/udp # DNP [Michael_Thesing]
lehrig@nb5lehrig:~/Downloads> grep -i modbus /etc/services
mbap 502/tcp # Modbus Application Protocol (updated 2014-06-10) [modbus.org] [Dennis_Dube]
mbap 502/udp # Modbus Application Protocol (updated 2014-06-10) [modbus.org] [Dennis_Dube]
mbap-s 802/tcp # Modbus Application Protocol Secure [modbus.org] [Dennis_Dube]
mbap-s 802/udp # Modbus Application Protocol Secure [modbus.org] [Dennis_Dube]
By Steve Myres on 27 February, 2019 - 9:25 am
Don't know which PLC you have and if it can do this, but with most PLCs it would work fine. There's no fundamental Ethernet issue with it.
