Monday, October 21, 2019
Photoelectric Sensors
Photoelectric sensor sees small gap in product spacing and machine faults on insufficient gap
when using a Sick retro reflex sensor to detect product in trays entering a Fuji flow wrapper, the sensor sees a small gap in the product spacing, and the machine faults on insufficient gap. Is there any way to prevent a sensor giving a double blip?
My email is crowther.steven@gmail.com
tweaking packing line automation is not a simple matter.
good luck
By James Ingraham on 6 March, 2019 - 4:47 pm
Yes. The most common way of doing this it with a delay-off timer in the PLC. You can also get time delay relays, which might be easier if you don't have access to the PLC code. I quickly found a multi-function timer relay available from an online distributor for under $40. (Note that I am in the US; other places in the world may have wildly different pricing and availability.) Sometimes, it can be as simple as angling the photo-eye a little bit, so that it doesn't look straight through gaps. Of course, that won't work if you need high repeatability in sensing the leading edge.
Good luck.
-James Ingraham
Sage Automation, Inc.
Thanks James, I will try altering the angle.
