Tuesday, April 23, 2019
Enthalpy Drop Across Steam Condenser
What is the best enthalpy drop across the air cooled condenser for steam turbine? What the effect of ambient temperature of the air cooled condenser?
Hi every one
looking for the below
what is the best enthalpy drop across the air cooled condenser for steam turbine?
what the effect of ambient temperature of the air cooled condenser?
what is the best elevation for the air condenser for steam turbine?
what is the effect of increase the pressure inlet the air cooled condenser for steam turbine?
what is the effect of moisture ratio(X)of steam interning the air cooled condenser for steam turbine?
what is the possibilities of causing back pressure in the air cooled condenser for steam turbine?
what is the factors that leading to select the right area for air cooled condenser for steam turbine?
All your questions relate to heat exchanger/condenser design, and require qualified engineering not just answers.
Operationally, the condenser is driven by the condensation temperature at the condenser discharge; that will drive the pressure at condensation, normally discharge pressure of common Steam Turbine discharges in secondary.
But, if you are not getting adequate condenser heat transfer, the turbine disch press/temp is higher and power down.
Get a design engineer involved.
