Submersible hydrostatic pressure level transducer uses a pressure level sensor of 316L stainless steel housing and MEAS TE diffusion silicon core as the signal measuring component. Through static pressure measurement principle, the liquid static pressure is proportional to the liquid depth and is measured. The information on the board is converted into a 4-20 mA or RS485 signal output. This establishes a linear relationship between the output signal and the liquid depth, enabling accurate measurement of fluid depth.
