In primary seal gas of ethylene compressor of our plant there are two variable area flow transmitter which are over range i.e 100 kg/h (10..10 kg/h). With a RO before these flow transmitters with bore diameter of 2.5 mm. First of all what could be the problem for this over range situation? What is calculation for flow range in regard to this RO? And what data we need to calculate flow? is it same as dp orifice flow or not?
I appreciate any help in this regard.
