Hello everyone,
I am begginer in Deltav, and I have a question regarding proplus configuration. I have read somewhere that proplus IP address is fixed and it is not possible to change. The primary IP address is 10.4.0.6 and secodary is 10.8.0.6. When I started to configure proplus workstation after selecting type of workstation a new window opens in which there are 3 parts as following:
1)primary card title and current ip address
2) secondary card title and current ip address
3) available LAN card title and ip address
I want to know if available lan card IP address doesn’t conform above mentioned IP address, then I should change it to 10.4 or 10.8?
For example, in my case the current ip address for available lan card start with 169.254. Should I change it and then assign to primary card?
Thanks in advance
Thanks in advance
