Saturday, July 20, 2019
Parameters Calculation for Siemens sgt2000e Turbine
Siemens SGT2000E machine performance engineering heat and pressure sensors for calculating efficiency in an excel sheet.
By Tony Ochigbano on 2 July, 2019 - 9:20 am
These are the key parameters. But I need how to collect them and extract reading. And calculations to produce efficiency.
Name Description
@00CXM00CM001_XQ01 ENVRMT AIR HUMIDITY
@00CXM00CM002_XQ01 ENVRMT AIR HUMIDITY
@00CXM00CP001_XQ01 ENVRMT AIR PRES
@00CXM00CP002_XQ01 ENVRMT AIR PRES
@00CXM00CT001_XQ01 ENVRMT AIR TEMP
@00CXM00CT002_XQ01 ENVRMT AIR TEMP
@13BAC01GS001_XB02 GEN CB 0/1
@13BBT01CE001_XQ01 U AUX TFR
@13BBT01CE051_XQ01 AUX ACTIVE ENERGY
@13EKG60CP001_XQ01 FG CONSU MET
@13EKG60CT001_XQ01 FG CONSU MET
@13EKG60FF001_XQ01 FG CONSU MET
@13MBA10CG101_XQ01 SHAFT POSN MEAS
@13MBA10CG102_XQ01 SHAFT POSN MEAS
@13MBA10CS101_XQ01 TURBINE SPEED 1
@13MBA10CS102_XQ01 TURBINE SPEED 2
@13MBA10CS103_XQ01 TURBINE SPEED 3
@13MBA10FG100_ZQ01 SHAFT POSN MEAS
@13MBA11CG101_XQ01 IGV POSN %
@13MBA11CP101_XQ01 PRES U/STR COMPR
@13MBA11CT101B_XQ01 TEMP COMPR INLET
@13MBA11CT102B_XQ01 TEMP COMPR INLET
@13MBA11CT103B_XQ01 TEMP COMPR INLET
@13MBA11CT901_ZQ01 TEMP COMPR INLET
@13MBA12CP101_XQ01 PRES COMPR OUTLET
@13MBA12CP102_XQ01 PRES COMPR OUTLET
@13MBA12CP901_ZQ01 PRES COMPR OUTLET
@13MBA12CT101A_XQ01 TEMP COMPR OUTLET
@13MBA12CT101B_XQ01 TEMP COMPR OUTLET
@13MBA12CT102A_XQ01 TEMP COMPR OUTLET
@13MBA12CT102B_XQ01 TEMP COMPR OUTLET
@13MBA12CT901_ZQ02 TEMP COMPR OUTLET
@13MBA22CT102B_XQ01 TEMP TURB OUTLET
@13MBA22CT103B_XQ01 TEMP TURB OUTLET
@13MBA22CT104B_XQ01 TEMP TURB OUTLET
@13MBA22CT106B_XQ01 TEMP TURB OUTLET
@13MBA22CT107B_XQ01 TEMP TURB OUTLET
@13MBA22CT108B_XQ01 TEMP TURB OUTLET
@13MBA22CT900_ZQ01 TEMP TURB OUTLET
@13MBL10CP004_XQ01 DP PULSE FILTER
@13MBL10CP010_XQ01 DP FILTER mbar
@13MBL11CT001_XQ01 DEW POINT TEMP
@13MBL11CT005_XQ01 WET BULB TEMP
@13MBL11CT010_XQ01 TEMP AMBIENT AIR
@13MBM11CP103_XQ01 DIFF PRES C-CL
@13MBM21CP103_XQ01 DIFF PRES C-CR
@13MBP13CP101_XQ01 PRES NG U/STR
@13MBP13CP102_XQ01 PRES NG U/STR
@13MBP13CT101A_XQ01 TEMP U/STR NG
@13MBP13CT102A_XQ01 TEMP U/STR NG
@13MBP13CT103A_XQ01 TEMP U/STR NG
@13MBP13FP901_ZQ01 NG PRESSURE bar
@13MBP13FT901_ZQ01 TEMP U/STR NG
@13MBR10CT001A_XQ01 TEMP DIFFUSOR OUTLET
@13MBR10CT002A_XQ01 TEMP DIFFUSOR OUTLET
@13MBR10CT003A_XQ01 TEMP DIFFUSOR OUTLET
@13MBR10CT004A_XQ01 TEMP DIFFUSOR OUTLET
@13MBR10CT005A_XQ01 TEMP DIFFUSOR OUTLET
@13MBR10CT006A_XQ01 TEMP DIFFUSOR OUTLET
@13MBR10CT900_ZQ01 TEMP DIFFUSOR OUTLET
@13MBY10CE901_XQ01 ACTIVE POWER MW
@13MBY10CE901_XQ91 ACTIVE POWER MW
@13MBY10CS901_ZQ01 TURBINE SPEED 1/s
@13MBY10CS901_ZQ11 TURBINE SPEED 1/s
@13MBY10DT010_XQ01 B-LOAD TEMP SETP
@13MBY10DU060_XT07 OTC CONTROLLER 0/1
@13MBY10EP801_XQ10 EQUIV OP HOURS
@13MBY10EP801_XQ14 OP HOURS >
@13MBY10EP801_XQ15 DYN OP HOURS
@13MBY10FE901_XQ01 NORMALIZED LOAD %
@13MBY10FT010_ZQ01 CALC TURB OT
@13MKA01CE001A_XQ01 GEN VOLTAGE L1-L2
@13MKA01CE001B_XQ01 GEN VOLTAGE L2-L3
@13MKA01CE001C_XQ01 GEN VOLTAGE L3-L1
@13MKA01CE002A_XQ01 GEN CURRENT L1
@13MKA01CE002B_XQ01 GEN CURRENT L2
@13MKA01CE002C_XQ01 GEN CURRENT L3
This is actually a perfect application for your solution - Dream Report. It will connect to your Siemens equipment, collect and archive your data, and then perform your performance calculations, delivering the results in reports or realtime dashboards as you choose. A small system for up to 50 I/O will cost you $1900 list price. Quick and easy to learn. Feel free to contact me directly - Roy.Kok@DreamReport.com
HELLO AND THANKS FOR THE REPLY.
I HAVE SENT AN EMAIL TO YOUR INBOX. DO REPLY.
THANKS
Hello Tony,
Efficiency calculations are easily performed in a workbook. That is why I suggest you look at XLReporter (www.Sytech.com) that has many built-in industry specific calculations. However, if your need is specialized, you can implement your calculations in a workbook template and have XLReporter gather the data and apply the calculation, automatically.
For $1295, this is light weight software that is heavy duty.
Email : sales@sytech.com or call 508 520 9957 to arrange a demonstration of the product.
