Saturday, July 20, 2019
How to take data from smart energy meter to Arduino Nano using RS485?
Interfacing Arduino nano with Ziegler smart energy meter using RS 485 Modbus
I have been working on a project. I have to take readings of Ziegler energy meter (http://www.zieglerinstruments.com/Product/Detail/192/Power-Energy-meter) on an Arduino nano using RS485 Modbus.
I have made this code:
#include<ModbusMaster.h>
#include<SoftwareSerial.h>
SoftwareSerial mySerial(2,1);
uint16_t m_startAddress[3] = {0x30001 , 0x30007 , 0x30013};
uint16_t m_length = 0x0001;
uint8_t result;
uint8_t ret;
int sta =0;
union
uint16_t u[2];
float f;
}meterdata;
ModbusMaster node;
void enableTx()
delay(2);
digitalWrite(7,HIGH);
void disableTx()
delay(2);
digitalWrite(7,LOW);
void setup()
pinMode(7,OUTPUT);
node.preTransmission(enableTx);
node.postTransmission(disableTx);
Serial.begin(9600);
node.begin(1,mySerial);
void loop()
result = node.readInputRegisters(m_startAddress[sta],m_length);
if(result == node.ku8MBSuccess)
if(sta==0)
meterdata.u[1] = node.getResponseBuffer(0);
meterdata.u[0] = node.getResponseBuffer(1);
Serial.print("Voltage: ");
Serial.print(meterdata.f);
Serial.print("V");
else if(sta==1)
Serial.print("Current: ");
Serial.print("A");
else if(sta==2)
Serial.print("Power: ");
Serial.print("W");
else{
Serial.print("Error");
Serial.println(result,HEX);
sta ++;
if(sta==3) sta=0;
delay(1000);
Can anyone tell me about the errors in this code?
You can go through this manual (http://www.zieglerinstruments.com/Upload/Documents/01%20Ziegler/Product%20Code/MFM/Ziegler-Delat-Energy%20Manual-E1R0.pdf)
Thanks for the help or advice in advance.
By José Luiz on 10 July, 2019 - 6:21 am
Good Morning!
I have no experience with Modbus. But with the above mentioned manual, I saw on page 35, table with end hex of the registers for Modbus. Example: the end 30001, for Modbus 0x0000; end 30007> 0x0006; and 30013, 0x000C.
Is this the problem?
Moderator's Note: This reply was originally in Portuguese. I used Google Translate.
Bom dia!
No tenho experiencia com modbus, mas consutando o manual citado, vi na pagina 35, tabela com end hex dos registradores para modbus. Exemplo: o end 30001, para modbus 0x0000; end 30007 > 0x0006; e 30013, 0x000C.
Ser¡ esse o problema ????
