Sunday, August 25, 2019
Condensate Pot Support
Condensate Pot for pressure transmitter installation.
Our project requires condensate pot for Pressure Transmitter installation whose tapping point for Gas Service is higher. I was told that the tubing can hold the pot. Do you have details for the support in case the pot is larger?
The pipe-fitters always seem to take care of supports without a lot coaching. Sometimes close coupled to a root valve. I have seen pipe, as opposed to tubing, used on occasion for support.
Slide 24 at Slideshare has AS-Schneider (Germany) supports for valves and measuring instruments:
https://www.slideshare.net/RemavalSasMantenimiento/as-0201gaugevalvesandpressuregaugeaccessoriesen
I'm curious as to why there's a condensate pot in a vapor/gas impulse line at all? Why not let any condensed liquid drain down into pipe directly?
I know these pots are old tech already. The client maybe conservative. Thanks for your reply. We moved forward with what you advised.
