12VDc to 110Vdc Battery Charger
Umairabbasi...
Welcome to Control.Com!
Q1) Do you mean you need to provide a 110 Vdc Load from a 125 Vdc Source?
Q2) Are the Negative side of both Load and Source grounded/earthed?
Q3) What is the maximum Amperes of the Load?
Regards, Phil Corso
1. Yes, we have few old Battery chargers and want to get rid of them since nearby battery chargers are dual redundant and have ample spare capacity but problem is they are newer ones with 125V dc and older boards are 110V rated.
2. From where we want to source they are 125Vdc 65Ampere, loading is not an issue since we have single 3.3KV board in each older substation so maximum 10A.
3. initially, we were thinking to reduce voltage by removing a cell and make it 119Vdc but newer boards spring charge motor in new substations are 125Vdc rated.
Umairabbasi
Regards, Phil Corso
