We have a number of gas turbine units installed at our gas processing plant in Pakistan. The site has high humidity & fog in the months of December and January. Due to high humidity/fog, DP (differential pressure) across filters increase particularly in colder hours (after midnight and early morning) which also results into shutdown when exceeded the trip limit.
Would you please share your experience operating gas turbine units and type of filtration (element type, inlet air treatment, self cleaning practices, alert/trip limits, pulse clean start/stop dp setpoints etc). Have you adjusted alert/trip & self clean dp start/stop on dp switch across filters or across ambient and compressor inlet (considering duct losses).
Appreciate valuable comments.
