We had a fan motor fail on one of our GE (Frame 6) Generator's Exciter Rectifier. It's a double shaft blower. My contact tells me the GE part is no longer available. The label plate (sticker) indicates that the motor GE used is a sample motor HF2H. It's 115V 1320/1580 RPM 7.5MFD 50/60HZ 6.0Amps 370 VAC and Thermally protected. The local motor shop we use normally says that the sample motor would have had more digits after HF2H if it was 'accepted'. I have a 2 day outage (just got shorter) to pull this motor and either find a replacement or ... rewound?... I was just wondering if anyone has encountered this and knows about this motor, and who may have one.
