I am designing a power plant have three generators with similar capacity. The output of each generator is 11kV, 2 MW, 50HZ, and the nominal current of each generator is 132A. all three generators will be run in parallel on a common bus bar. I want to install an NGR to protect the generator from the earth's fault current. kindly anyone guides me on how can I calculate the NGR resistance and current carrying capacity.
