Hi
I wanted to have some information regarding the NEC standard. In the design part, that is when I am making the diagram, I was told that the distances between each device must also be added when completing the technical drawing because otherwise the NEC standard is not respected. It is true? Does the NEC standard require me to also write the distance between devices and their dimensions?
