I have 2 CPUs (s7-314C-2DP) and a multipanel MP370 of Siemens. I've specified the parameters for DP port in HWconfig for both CPUs (speed, master/slave, address,) and setup a profibus circuit in netpro; and of course in protool for my mp370 panel.
But when I want to download the program it is only possible from MPI port of each CPU although I want to download from Master CPU to both of them.
What is the procedure to setup that?
also I can not download to mp370 panel. it has a 9 pin port for config/printer and a 15pin port rs232 for plc 1f1a and a 9pin port rs485 for plc and a cf card and pc card slot. when it restarts I choose transfer (ports are enabled from control panel) but it doesn't start downloading. I never had this problem with TP and OP series.
thanks.
thanks.
