We just carried out a CI on the unit (Frame 6B - MS6581) and have re-used all CI hardware as they were all in good condition. This included the Fuel Nozzles. While the unit was being started and running up to FSNL, we get very hight spreads with the T/C profile looking like a bathtub curve with the low or cold area over the T/C numbers 6,7,8,9 & 10. The spreads gets as high as 274Degc (Sp1 274/ Sp2 269/ Sp3 265) but eventually settled back down to about 66 DegC (Sp1 66 / Sp2 57 /Sp3 54)when the machine gets to FSNL and settles over a period of about a minute. The Allowable spread also follows a downward trend untill it gets to around the mid 50's. The machine then trips of\n combustion trouble.The spreads on this unit were fine before we shut down for the overhaul. However we only have the base load spread info which was Sp1 30, Sp2 27 and Sp3 24. We do not have the FSNL data prior to shutdown to compare.
What is interesting is that the low or cold area stays fixed over the same thermocouples (6,7,8,9 & 10) as the machine runs up to FSNL.The curve or depression gets smaller as the machine settles at FSNL but the cold area is still stays over the same T/C's. I would have thought that if it was a fuel nozzle or can hardware problem, the cold spot would move along as the engine runs up to FSNL, just as you would expect if the laod was changed. We are unable to synchronsie the engine and load it up to see what happens due to a transformer issue that we are working on.
Any comments would be welcome.
