I have been working with smart instruments and most of the come with a feature called "Damping Value for Process Variable Measurement".
The quick description of the parameter goes: The sampling interval used to smooth the output.
I would like to understand in which cases it would be recommended to set a damping for the process variable and how exactly does the damping work?
