I need help with S300.
I need to add another recipe in my program via DB (data block) which is needed to operate machine. Every recipe is stored in his own DB and it has a list of numbers which corresponds with operations.
Actual recipe is then loaded in main DB from which program is performing actions...
I made another DB but it always has values from my old DB (which i used for template) initial values are mine but actual values are from old DB and then old values are loaded in main DB. I try online changing it but when i reset PLC everything is back to old values.
Is there any solution that doesn't include building a new DB because there is more than 500 values in a recipe
Thank You very much....
