H
Situation:
Generator produced an output as 500MW where the load demand are same as 500MW (sych into grid).
If the load suddenly increase up to 800MW or decreased down to 300MW (value is just for the example-assume that the grid is small/weak). What will happen to the generator?
Question:
1) Can you please help me to brief this phenomena which is related with the frequency? - with formula, better. I can't see the relationship between Watt, Hertz and Governor when the situation above happened. Those 3 elements struggling me.
additional where; F=(P*N)/120 and P=(3^.5) VI cos phi.
2) And what is happening to the excitation, when Watt increased/decreased? Is the excitation should act to support with VAr action, because the power factor must maintain at 0.9. If yes, How it works?
Thanks with Regard
Question:
Thanks with Regard
