HELLO
We have Gas turbine Frame-V with MARK-Vie control system and turbine is in running condition.
One alarm is appearing frequently "Vibration high" BB3 in generator on its HMI. We checked the vibration Device and we found it not well. Then we decided to change it. We forced BB3 corresponding device vibration in 0.18 in/mm and we disconnect the cable from the sensor. the turbine tripped.
Please We want to know, why the turbine tripped after all BB3 is congeal by forcing the value in 0.18 in/mm.
Thank you
Thank you
