G
Island power system in a facility with 2 X 2MW 400V, 50Hz, 1000RPM Gas Engine Driven generators A & B, each capable of supplying the plant total load. The problem is, Gen A works perfectly by itself but Gen B can only work if paralleled with Gen A. If Gen B is working alone (for 2-22 hours), the voltage suddenly drops to about 200V and trips the plant. We have checked all wiring, rotating rectifier, AVR and governor settings, everything looks OK but the issue still persists. Please, does anyone have any ideas on what else to check?
