Hello every body;
Our power plant:
3 gas turbo generators, frame5, GE, single shaft, 5100 rpm, Gear Box 5100/1500 RPM,
Our Plant:
approx. consumption 15 Megawatt.
the large motors in plant are two 4 Mega Watt elector motors with soft starter(Gas Comp. driver)
Problem:
when our power plant (normally one GT generator) feeds the plant and parallel with Grid,every thing is OK.
In Island mode, where we are disconnect from grid, and our plant supplied by one or two GT generator, exactly when we start the 4 MW elector motors, the in GT generators gear box occurred vibration and will trip the generators.
4 MW motors have one harmonic filters to compensate the 5, 7, 11 harmonics.
any help will be appreciated
Ali Shakarami
Our power plant:
Our Plant:
Problem:
Ali Shakarami
