Took temperature readings with Omega J type thermometer but only had K type wire which I twisted into a junction. Problem is, I have no idea how to convert this data and it took hours to obtain and I had only 1 chance. Again, I used a J type thermometer with a K type wire. The readings were obviously way off but had no time to get J type wire.
The actual temperature ranges checked were at 200'F and 450'F.
Any formula I can use to convert this data?
Thanks so much in advance, Michele - [email protected]
