I'm not a control engineer nor have I played one on television. Never the less this question has landed on my desk. I've done a google search as well as a search on this site without success. All I can find is voltage to temperature conversion. It seems a piece of equipment was ordered specifying T type TC's. Unknown to the engineer and technician it arrived with J type TC's but they used T type equipment to measure temps. and now want to know if there is a way to convert the temperature readings they recorded back to the correct equivalent T type reading. I've told them I don't believe that it is possible without knowing what the cold junction temperature was and maybe not even then. Is it possible to do this even if one had to approximate the CJ temperature? Thanks
