There is a flow transmitter that its impulse lines are connected
to a vertical line (between them there is an orrifice).
The flow comes from down to up and the impulse line is connected correct to the transmitter (H is down from orrifice L is up), but there is a difference between them about 8 cm. the range of transmitter is 0 to 4000 mmh2o.
so, in order to have an accurate measurement need to do a zero trim (when there is no flow) or it is correct as it is?
Sorry for my bad English!
