R
We are having problems with our Solar Turbine. Its a 1040 HP Turbine and we just recently replaced the Accessory Drive. Everything seems to work like its suppose to, but when we get to the part where its suppose to fire off, it just stays running and eventually drops out. We checked the PCD and its only getting to 1 lb. We don't know where to check to see why we're not getting enough fuel.
Needing some knowledge on this subject. Thank you in advance.
