The existing Frame 7E Gas Turbines. A retrofit on the control system was carried out migrating from Mark II to Mark V Speedtronic Control System in the year 2000.
We have been working to improve our starting reliability and have studied the causes of failure to start. We have identified that failure of the clutch to engage within the 5 second allowed time is the most significant cause of failure to start. We have checked all the system components and system settings and rectified any faults found. We have achieved some improvement but still note that failure of the clutch to engage remains the most significant cause of failure to start.
To understand the cause of the unreliability we have studied the installed starting sequence in the Mark V CSP. The control sequence is that the Auxiliary Hydraulic Pump start command and the Starting Clutch Solenoid Valve (L20 CS1) energization are simultaneous with the Start Command and the Master Protective Relays energization. We have observed that in this sequence the hydraulic pressure takes approximately 8 seconds to build up to 105 bar as the accumulators fill. We observe that this means that during the clutch operation it is therefore not supplied with 105 bar as suggested by the Hitachi detailed hydraulic drawing 10R181-732. We propose that this situation means that the reliability of clutch operation is compromised.
We hold the view that the Auxiliary Hydraulic Pump should be started before the clutch solenoid is energized and the hydraulic oil supply pressure (105 Bar) shall be actually made available before the Clutch Solenoid Valve (L 20CS1) energization.
Our view is supported by the improved clutch engagement reliability that we achieve when the auxiliary pump is started in manual before initiating the start sequence. In tests we have carried out we see that we achieve a much more positive clutch engagement and significantly reduced time between clutch solenoid energization and clutch limit switch activation when the auxiliary pump is already running and system pressure is already 105 bar.
I am look forward to hearing from you in due time.
