Hi all,
The plant has Frame 9E gas turbine, simple cycle, 125 MW, and operates on HFO fuel. When the load reduced to about 40 MW a fluctuation happened in the signal of the flow divider and an alarm appeared (combustion trouble). The temp. of the fuel is constant at 75 c , so why this problem is appear? And how can it be solved?
