what causes the turbine fail to fire at startup on gas fuel?
GIVEN:
1- turbine frame: 5
2- Control system: MK II
3- 14HM>> 1
4- Spark Plugs work properly.
5- Gas Pressure(P1)>>17 bar.
6- At fire instant>> GCV responds and the piston opens about 50% on scale.
7- P2>> about 4 bar and the turbine couldn't fire.
8- Made a bypass gas line across the gas valve with a manual valve.
9-the turbine fires only by opening that pilot line and by closing it again after firing (30% speed).
the turbine continue to startup up to FSNL normally. what is the reason?
GIVEN:
1- turbine frame: 5
3- 14HM>> 1
