I have an application where we need to understand the voltage and current being output from the drive to the motor (one leg of the 480VAC, 3-phase motor). We are using a Reliance Electric GV3000 drive. I started with a simple AC current transducer but that won't work on the output side of the drive since the frequency changes anywhere between 3-200 Hz.
Is anyone out there have a similar application or have done this before? Is there a transducer or instrumentation out there that can do this? What is the best way. I need to be able to monitor continuously and need to monitor that value in the PLC.
