We are having two nos. Radar level Gauge from Enraf Honeywell in our Mounded Bullet. Initial calibration/masking was done and was working fine. After taking liquid propylene inside, both the gauges started giving wrong readings (+ve side).
As per the vendor pin orientation is not correct and need to be aligned in the same line.
Need your valuable inputs.
