P
I am using a drive for closed loop speed control. The drive monitors the frequency from an encoder, and adjusts the output to a motor so that motor speed is controlled at setpoint.
As a way to test and document the performance of this drive system, I would like to find a data recording instrument that would be able to log/record the frequency of the encoder signal over a period of time. Currently, I have a 240 PPR encoder and my motor speed range is 0-1750 RPM, so my frequency range is 0-7000 Hz. Ideally, I would like to be able to record frequencies as accurately as possible at 0.1 second intervals.
If anyone could recommend an instrument that would have this capability, I would greatly appreciate it.
Thanks in advance,
Paul
Thanks in advance,
Paul
