R
Good day friends,
We are facing a problem with our Gas turbine (Frame 5, TMR, Single shaft, Speedtronics MARK 5 control)from long back.
Problem is P2 pressure is hunting about 10 to 15 psi and load also hunting about 0.3 to 0.5MW due to this problem.
One year before, we have changed the new SRV/GCV full valve assembly (refurbishment) and calibrated by vendor. After 10 months, we have faced the same hunting problem about 2 to 3MW. We have changed the servo valves both SRV/GCV and calibrated. After that fluctuation was reduced, and we found some dust particles inside the servo filters. We changed the reservoir oil and again same problem came after 2 months. When we are changing from gas to liquid fuel, we found there was no hunting and load also stable. Again changeover to gas, P2 pressure was stable for some 2 to 3 days and again it will start to fluctuate. Till date we have changed SRV/GCV servo valves 3 times and GCV cylinder also changed one time.
Vendor from GE has been analyzed all the control parameters and finalized to change the whole valve assembly. But as per our records, we have changed everything which is involved in this problem including FPG2. we did FSR gag and checked the GCV performance. It is stable. Vendor told it’s SRV problem and adjusted the control gain from 1.9 to 1.71. SRV is responding good at offline. At FSNL its started hunting again and same fluctuation repeated.
Give me a solution friends. what all parameters to check?
regards
RK..
regards
RK..
