H
For measuring Boiler Steam drum water level by DP transmitter, I noticed always using Low side of DP transmitter is connected to the filled wet leg. while the high side of the DP transmitter connected to the bottom side of the drum so the reading is always negative. Is there any reason for this installation way? why not reversing it so that reading be in positive?
