I am Using IE-CS-2TX-1RS232/485 is a Serial to ethernet converter from Weidmuller. I need to communicate and convert a serial signal from a flow computer to tcp/ip to my laptop the program that I use as a client is Radzio Modbus Master Simulator.
The Serial to Ethernet converter from weidmuller is configured as TCP server. The converter weidmuller don't have the option RTU over TCP/IP I think that is my problem but someone have a solution for this? i appreciate any help thanks.
I made this application with another Serial to Ethernet connection and it works is the ADAM-4572 Which have the option "Modbus Slave mode" thank you.
e-mail [email protected]
