We are replacing our Honeywell TDC3000 DCS on a plant. The new DCS is Centum VP with software release R6.03.00. I have come to know that the software requires Windows 7 Pro 64-bit SP1 with 8-GB RAM.
I want to install the software in a virtual machine on my PC for learning / engineering purpose.
Tried Windows 7 Virtual Machine software but we came to know that it doesn't support 64-bit guests. Then we tried Oracle's Virtual Box. We were able to install Windows and Centum VP software, but the virtual machine crashes as soon as the Test Function is started.
My question is: What is the minimum requirement to install and run Centum VP in a virtual machine? Can it be installed on a 32-bit Windows? If so, I can stick to Virtual PC instead of Virtual Box.
Mind that I am not deploying the machine in a production environment. I only want to run the software in a VM for learning purpose. Before that, I have used Centum CS3000 software very conveniently on a virtual PC.
