V
We have 6 GTG frame 9 mark VI control. After major inspection (MI) of one of our gas turbine when we are going to give command for cooldown mode, torque converter (TC) output not rotating. Other checks/observation are:
1. Torque converter input shaft rotates.
2. From inspection window we have check the operation of VIGV inside torque converter, found working normal.
3. Fixed the PG at supply & return line found pressure in normal range that confirm that fluid going from pump to turbine.
4. By decoupling the AGB & TC coupling , TC output shaft rotate freely.
5. During inspection & final alignment turbine & generator shaft rotate ok.
6. Checking jacking oil pressure of generator shaft, found normal and generator shaft lift observed ok.
But when all things combines torque converter output shaft not rotating.
