I was asked to look at the tuning parameters for a generator oil cooler control loop for a GE Frame 7. It is being controlled by an ISA_PID MK-VI block. I searched for help files on the internet without success.
The plant is in another state and I haven't worked on a MK-VI for nearly 20 years.
Specifically I need to know how the proportional gain is scaled. The PG pin of the block is set for 5.4%/%. I'm thinking that for every % error there is a 5.4% output response. i.e. a gain of 5.4. That seems really high, but the trends I've seen look like the response is way too fast.
There is a pin labeled DA. It is currently set for 10. Any idea what that might be? The DG pin, I'm assuming is derivative gain, is set for 0. Would the derivative gain units be seconds or minutes?
Thanks so much,
Mully
Thanks so much,
Mully
