Need to calculate flow in a long open channel.
One Venturi is installed at the entrance and three Dall Orifices are installed at the exit.
Variations in readings are large.
A 22 km channel, 20 m wide, 4.5 m deep, with a trapezoidal profile is used to convey water from a dam to a large water purification plant.
Operating flow range: 2000 to 3000 Ml/day
Need to re calculate the Venturi and the Dall Orifices. Current reading ariations amongst these equipment is +/- 7%.
A) Does anybody has data on Dall Orifice calculations, installation? and accuracies?
b) Any idea how to measure the flow in the canal
by other improved means?
Sam
Sam
