R
I need to control valves that are located on the other side of a highway from the main control. Distance is less than 1000'. Long range radios seem like overkill and are relatively expensive. Is there a cheaper short range device? I'm currently using a battery device with no communication whatsoever with the main control, so I'm open to all options.
