We have recently installed a turbine type flowmeter make: fliud control our op. range is 12000cu.m/hr, media: Natural Gas.Loop powered, programmable menu.
At our w/s we don't have the equpiment to calibrate this meter. It is nearly two year that we have not calibrated, this is used for metering the total flow. We had requested for external calibration for this inst. But the calibration Service companies say that they only calibrate the signal cond. unit by simulating frequency. But we want to be sure that the rotor is also in good condition. Is it possible to calibrate (bench) by actual process media. Or the only option is to check the signal cond. unit.
thanks
thanks
