The pump I will be controlling is a the model number Masterflex EW-7523-40. This is a pump made by Cole-Palmer. We are going to be setting up a color control system on a laboratory papermachine. We are using several devices that use RS-232C communications. We are using a serial-ethernet terminal server due to the layout of instrumentation and controlling pc hence the desire to control the pump through a serial port. The pump has a DB15F connector on the back. I know I need some type of external i/o device to interface the pump with the serial connection that has DAC, ADC, and relay capabilities.
I need to be able to trigger 3 contact closures all of which have a common ground. The pump output is selectable from 0-20ma, 4-20ma, or 0-10V. The input has the same choices and finally I have the option of either an NC or NO contact for monitoring if the pump is running. If I had the time and experience I imagine I would build some type of custom PIC to handle the job. What I am looking at doing is using a device that has analog i/o and then adding on relays to handle the contacts.
This is all new to me so I was looking for any suggestions you might have. Specifically I was wondering if there was a way to handle the contact closures other than using the relays and how to handle monitoring the NC or NO contact. Thanks in advance!
Bob Lewis
Bob Lewis
