V
One of our Frame-7 turbine controlled by Mark VI and driving gas compressor - trips on high high vibration at around 68% every time it is started.
We have starting motor connected through torque converter and SSS clutch to turbine shaft.
Also there is a VFD helper motor that is directly coupled to the other end of the gas compressor and helps the startup from 28% of TNH.
The sequence of events as below:
Turbine reaches around 68% speed.
CPD drops from 30 psig to 18 psig in about 0.2 seconds.
Simultaneously vibration increases upto trip levels in bearing No.2 and alarm levels in bearing No.3
Turbine trips on high high vibration
Any thoughts would be much appreciated.
